header problems
Old Jan 20, 2004 | 09:17 PM
soundmaster's Avatar
Default header problems
SLP LT Headers.
The car makes this hissing sound coming from the headers. The car doesn't sound clean... it sounds like an old car. Does anybody know what is causing this and how to fix it? Should I check my sparkplug, o2's?
Also, my check engine light comes on every once in a while. I took it to the dealer and they said it's caused by the exhaust and it's affecting the o2. I don't think it's caused by the exhaust... probably the headers. Is my O2 not working properly?
Old Jan 20, 2004 | 09:23 PM
SSTYCOON's Avatar
Originally Posted by soundmaster
SLP LT Headers.
You probably Have a header leak, What codes are you getting?, Did you hook everything up properly?
Properly installed headers will not cause an SES light to appear.
It may take a few 100 miles for your PCM to learn the new exhuast flow,
Reset the PCM,
I wouldn't even have gone to the Dealer, waste of time
Old Jan 20, 2004 | 10:02 PM
wrencher's Avatar
wrencher
Your gonna need to get the code #, & like said you prolly have a leak.
Hows emissions gonna go over in Cali with those headers?
Old Jan 20, 2004 | 11:54 PM
What do you mean by a leak - crack in the actual headers? - or headers not installed tight enough?
They didn't give me the code.
The headers do not pass emissions.
Regarding proper installation, my gut feeling tells me that something may not be right. I may have to have it re-checked.
Also, my fuel pump just went out for the second time in 1 week. I just tried starting the car a little while ago and the car won't start. Damn, this is the second time... the dealer replaced the fuel pump just today! Do you think the headers and fuel-pump incident is related?
