TB cam has play in it; repair or replace?
If I grab the front of it, it will ever so slightly wiggle left and right, altering the TPS voltage by .02-.04V, which changes the TPS% reading 1-2% when closing the blade under random cruise and idle conditions. My tuner (Frost) says not having this always come back to 0% when the blade is closed will cause drivability problems.
Is this something that can be repaired, or do I need an entire new 4-bolt cable-driven TB? If I get a new one, I want one which has adjustable blade stops at both ends of travel, one which isn't a airflow hinderance, and is relatively easy to tune through mail order tuning. This is mated to a LS3 intake/motor.
