Who sells torque straps?
Wildcat. This critter had a torque strap that was
kinda factory-ghetto-cute. Basically a steel cable
with those swaged clamps on it, and two 1/4"
formed steel loops; one bolted to the upper A-
arm, one to the exhaust manifold bolts. It might
be a way to go, do the same but use the strut
tower and exhaust (longer bolt or stud, they used
those combo bolt/stud/nut bolts that GM hung
iron-block accessories with.
You could get a coated cable swaged to length at
a better-grade hardware store, etc. The end keepers
you'd probably have to cobble but this is not much
of a challenge.
Just a thought.
