I need just a single fireproof sparkplug wire cover.
Old Jan 21, 2004 | 03:23 PM
Scalpel's Avatar
Default I need just a single fireproof sparkplug wire cover.
Do they sell them single-y? One of my Taylor wires sits VERY close to my Dynatech header and I'd like to get just one cover for it. Thanks.
Old Jan 21, 2004 | 06:17 PM
WILWAXU's Avatar
Usually you can twist the spark plug boot to clear.
If not, get a piece of insulating cloth tube. More hot rod shops have it.
Old Jan 21, 2004 | 06:34 PM
XLR8NSS's Avatar
Adkoonerstrator
Just wrap some aluminum foil around the spark plug wire in question. It works great.
Ghetto engineering, Terry Burger would be proud.
Old Jan 22, 2004 | 07:36 PM
Scalpel's Avatar
I actually thought of and did that but I didn't know if it'd "cook" the wire if heat got under the foil and insulated the heat IN on the wire. I did have Al foil wrapped around the one in question , I was too embarrassed to admit it though
Old Jan 22, 2004 | 08:06 PM
WS6FirebirdTA00's Avatar
the aluminum foil should deflect the heat, as long as u have enough on there where it wont heat through. wrap it a few time. should be fine. we used aluminum flashing in a fire place me and my friends made a fort back in the day ( im 19 so it wasnt but like 5 years ago lol ) anyway the flames were right on the aluminum and the wood didnt even get hot. tell me i cant do something ha i proved them wrong. i knew it woudlnt catch everything on fire lol so if its thick i dont see it being a problem, like i said the wood wasnt even that hot with a 3 hour fire
Old Jan 22, 2004 | 09:20 PM
XLR8NSS's Avatar
Adkoonerstrator
Yeah, I wrapped the complete wire up from the boot up past where it's close to the header tube. I also wrapped the foil around multiple times. I can take a picture, I ain't embarrassed.
Actually, I should check the wire and make sure it's not well done first. I haven't seen any sparks or glowing lights from under the hood at night so I think it's OK.
BTW, if you're worried about the wire get some of this header wrap and wrap a few inches of the header tube where it's close to the wire. This stuff is great.
http://store.summitracing.com/partde...rt=THE%2D11001
Also, get some of the snap straps to attach the header wrap. The straps are Summit part number THE-13002
Old Jan 22, 2004 | 09:30 PM
yeah i used header wrap. a friend had a roll so i didnt need to spend a fortune on it for jsut a little bit
Old Jan 23, 2004 | 08:10 AM
Scalpel's Avatar
Thanks for the tips, fellas
Old Jan 23, 2004 | 08:16 AM
Viper's Avatar
I use Accel 9000 wires; withstand the heat just fine.
Old Jan 23, 2004 | 08:38 AM
cne411's Avatar
NAPA here sells the boots packages of 2.
