Dyno
Old Jan 21, 2004 | 08:45 PM
Snk Sknr's Avatar
Default Dyno
Can somebody explain the difference between peak and under the curve power when looking at a dyno...
Old Jan 21, 2004 | 08:51 PM
AZLS1's Avatar
Peak is the highest point on the graph.
Area under the curve is the total volume under the entire HP line.
Old Jan 22, 2004 | 09:20 PM
cm02WS6's Avatar
Yeah, imagine if you had peak of 350 HP, but only over a very short RPM range. It wouldn't do you very much good. When someone refers to a good power curve, then it is high and WIDE, giving you a lot of useable power over a wider RPM range.
Old Jan 22, 2004 | 09:48 PM
WS6FirebirdTA00's Avatar
problem is people look at peak power not under the curve. if i have 400 hp top end people would that thats great but if i have 200 everywhere else that sucsk. but if i have 300 top end and 300 under the curve that is a lot better. u only hit peak power for a little of the rpm range, u want to get the under the curve numbers up
Old Jan 23, 2004 | 10:54 PM
Snk Sknr's Avatar
Default Dyno
Thanks guys! Now I understand.. So higher and wider is always better..
