stock motor mounts
Old Aug 8, 2010 | 06:28 PM
bigc98ws6's Avatar
Default stock motor mounts
supporting mods below,i was wondering if there is any power loss or is it bad if the motor is torquing to much on the stock mounts???
Old Aug 8, 2010 | 06:49 PM
RA032926's Avatar
are the mounts new?... if not they probably need to be replaced... i would go with poly inserts and trans mount or solids... i'm sure there would be a small amount of power loss through the drivetrain but not a huge amount, probably only noticeable on a dyno, but i could be wrong
Old Aug 8, 2010 | 09:27 PM
Funkster's Avatar
Agreed on the above.
If they are old you might as well go poly. Solids would be even better. Little more vibration, but well worth it.
Old Aug 8, 2010 | 10:26 PM
Pocket's Avatar
If the engine moves around too much you risk breaking parts like exhaust welds, trans mounts/cases, etc
Just go ahead and get polys or solids. You will like the difference
Old Aug 9, 2010 | 06:02 AM
Orange Juice's Avatar
I hated my poly mounts, they sent a buzz through the whole car.
