what size of fuel injectors to go with
Well I just spoke to someone at Katech and based on his calculations on a NA engine with 58psi fuel pressure they should max out around 650hp.
He said they are basically the same as the LS7 injectors.
LS1-style tall injectors
-Also known as ASA injectors
-38lb-hr @ 58psi
-EV1 style connector
-New in GM box
-Price is for 1 injector
i'm sure,,,, Katech made a mistake just like any campany can do ,but they are 38lb behind the supercharged Grand Prix and Regal 3.8 fuel system.
Also from a sponser on here FICINJECTORS said this about them bellow↓↓↓↓
Originally Posted by FICINJECTORS
I wanted you to know what the injector was first.. In an ls1 they will flow a tad over 42..
