Fuel pressure guage help!!!
my friend has a 00' SS camaro. he bought an autometer fuel gauge for the car. he has the sender and everything he needs. the sender has AN fittings on it. now i know the entire fuel line is hardline. and there is a hardline to AN adapter that i can get and probably make it work.
is this the correct way to install it?
can someone tell me how they installed theres?
Thanks
Anthony
Thanks
Anthony
this is what you need Metco Motorsports PN MFP0001. it's a fitting that will go on the end of the fuel rail where you would pressure test. you must remove the schrader valve from the fuel rail before install.
