So Spohn Solid motor mounts really do raise the motor...
Old Aug 24, 2010 | 01:53 PM
Z Fury's Avatar
Very interested to hear what the PAs do to the engine height. I want to do solid MMs, but would rather not fight a fitment issue doing the header/catback install.
Old Aug 24, 2010 | 05:13 PM
WagnutSS's Avatar
im with Z fury... i dont want to get burned on a fitment issue
Old Aug 24, 2010 | 11:38 PM
Mumbles's Avatar
Originally Posted by Arc00TA
Yeah I caught that after I posted, just didn't feel like deleting my post. Regardless, even with less clearance it shouldn't be an issue since it can't move any more now?
Sorry. Didn't mean to come off as a smartass.
You're right. With no movement, the smallest amount of clearance should be sufficient.
Old Aug 25, 2010 | 01:34 AM
LilJayV10's Avatar
Spohn has a tendency not to tell you anything. That's why I stopped using his stuff and went to UMI.
Old Aug 25, 2010 | 02:21 AM
taman86's Avatar
IMO i think you pay a higher price for the name on the part. look at any other equal suspension or chassis part from any other aftermarket company and guaranteed it will prolly be cheaper. i try and steer clear of spohn. kinda like going with BMR over UMI, exact same thing, just one is tid bit cheaper. sorry kinda of off topic there....my bad
Old Aug 26, 2010 | 01:41 AM
BennyB's Avatar
so who else sells solid mm's for cheaper? I want to buy some, but its hard to find anything other than spohn
Old Aug 29, 2010 | 09:28 PM
Z Fury's Avatar
No idea. I can't find anything other than Spohn, not even on Ebay.
Also, bump for updates.
Old Aug 29, 2010 | 09:47 PM
Element's Avatar
Aside from the PAs, I don't know of any either. I think Spohn is the only suspension company that makes a k-member that works with solid mounts, too.
If the mounts do wind up raising my engine, my car's going to get some BFH time...test-fitting my TSP duals, and I've got about 1/8" clearance on the driver's side header pipe, at the little rectangular body panel piece that runs across the car. If the engine goes up, so does the exhaust, and out comes the hammer.
Makes me wonder why in the hell the driver side header collector needs to be angled so far out away from the centerline of the car....there's nothing (at least on my car) that needs the clearance there. Hopefully the Kooks collector is angled a little better.
Old Sep 7, 2010 | 09:25 AM
69lemansguy's Avatar
update?
Old Sep 7, 2010 | 09:50 AM
Element's Avatar
Car goes in to the shop today, so I should have it back in a few days.
Old Sep 8, 2010 | 07:27 PM
xssive's Avatar
This may interest some of you. Motor position is unchanged with these
https://ls1tech.com/forums/parts-cla...or-mounts.html
Old Sep 18, 2010 | 04:12 PM
  #32
Element's Avatar
Just got my car back today. Engine still clears the STB fine with the solids on, and the header collectors have plenty of clearance at the floorpan. If it did raise the engine, it did so less than 1/4".
Bad thing: the shop told me that based on the welds on the mounts, they wouldn't recommend them for higher-power applications (even a decent cam). I guess you could have a good welding shop grind the welds off and re-do them if you wanted.
Old Sep 18, 2010 | 04:59 PM
  #33
1NASTYZo6's Avatar
To the OP my thought would of been to not cut the header but take the mounts out and have them cut down 1/2" on each side and welded back together.
My .02
Old Sep 19, 2010 | 11:39 AM
  #34
98RedBird's Avatar
Never once heard that.
Old Sep 19, 2010 | 12:32 PM
  #35
BADD SS's Avatar
Just curious why you dont like the poly's? The spohns do raise the engine a bit...
Old Sep 19, 2010 | 01:04 PM
  #36
Element's Avatar
These aren't the Spohns, which are supposed to be pretty damned durable.
Old Sep 19, 2010 | 01:41 PM
  #37
Duffster's Avatar
with all the complaints, why don't they offer another set that will lower the engine by say 1/2" or even a 1" drop set? There might be a market for something like that right?
Old Sep 20, 2010 | 12:10 AM
  #38
98RedBird's Avatar
Ah, okay, apparently I missed that you weren't using Spohns.
Old Sep 20, 2010 | 10:48 AM
  #39
Element's Avatar
I think the thing is, Spohn doesn't say the mounts raise the engine, so I doubt you'd be able to convince them to build a set that "lowers" the engine, even though they'd really be stock-height solid-mounts.
Poking around some, Madman makes a set of solid mounts, but they're marketed as race-only and are a little steeper than the Spohns.
I'll try to get a couple pictures this evening of collector-to-frame clearance, and clearance between my intake and fat man grab bar (er, STB).
Old Sep 29, 2010 | 02:52 PM
  #40
98ssls133's Avatar
Did you get a chance to take the pics of the clearance?
