Are SFCs visible from the side?
Old Sep 3, 2010 | 06:54 PM
skopers3's Avatar
Default Are SFCs visible from the side?
Looking into buying a pair and been doing research but didn't see anthing about this or pics other than from under the car. Just trying to decide if I want black or red and was curious if you can see them if you stand back.
thanks.
Old Sep 3, 2010 | 07:03 PM
Choppers's Avatar
Go to Suspension and I am sure somewhere will respond quicker in there than here.
Old Sep 3, 2010 | 07:12 PM
Sommer86's Avatar
My boxed weld in UMI's I installed last sunday are only slightly visible from the side. Basically you need to be on your knees parallel to the ground to see them.
And you can only see about an inch or less.
Old Sep 3, 2010 | 08:38 PM
Z Fury's Avatar
This. They are easier to see if they are red (on a non-red car), but you will usually have to be almost at ground level to see them.
Old Sep 3, 2010 | 09:34 PM
Apex8's Avatar
My weld in BMR ones are super visible they are silver so they dint really stand out. And this is on a TA so it has stock side skirts. Would really stand out on a formula or camaro
If you are about 10-12ft+ back you can see em
Old Sep 3, 2010 | 10:32 PM
BobP's Avatar
Ditto on the weld in BMRs. Check the pics - 1, 2.
BobP
Old Sep 3, 2010 | 10:46 PM
Mumbles's Avatar
I have SLP Bolt On SFCs. You can just barely see them from the side and that's only if you're looking for them.
Old Sep 4, 2010 | 12:34 AM
skopers3's Avatar
Thanks for the responses guys! Was trying to decide between black or red and think I'll go with red now.
Old Sep 4, 2010 | 12:39 AM
Midnight00SS's Avatar
Just put the Sphon ones on my car, and they fit nice, cant see them at all from the side, u have to go underneath to look
Old Sep 4, 2010 | 01:19 AM
99SSJarhead's Avatar
My boxed SLP's are highly visible which sucks cause they are also a nice shade of rust. Gotta get under there one day and sand and paint those things.
Old Sep 4, 2010 | 11:45 AM
sjsingle1's Avatar
my UMI 3 pts are visible.....but they are red on a silver car
Old Sep 4, 2010 | 01:09 PM
Bo White's Avatar
The Competition Engineering ones I had on my 94 and 98 fit real tight up against the car. You had to look for them to see em.
Old Sep 4, 2010 | 01:17 PM
yabadaba's Avatar
You can't see my UMI tubular weld-in's unless you actually look under the car. From any normal angle you'd never know they were there. I think the tubular SFC's tuck up to the chassis a little closer than the boxed ones.
Old Sep 4, 2010 | 05:15 PM
UMI Performance's Avatar
Hello,
Like many have mentioned with our SFC's you need to virtually be on your knees to see them on the car. If you go with black you would really need to know what you are looking for. Our tubular 2-points tuck up the best and you basically need to lay down to see them, this is part # 2001 and 2002. If you have side skirts like someone else mentioned they will hide the boxed and 3-point.
Hope that helps!
Ryan
