Belts squeal like a pig!
Old Jan 26, 2004 | 02:07 PM
Steve98Z's Avatar
Default Belts squeal like a pig!
Thought it was the water pump then the alt. but I hit it with a shot of WD-40 and it quiets down for a minute then promptly returns. The belt looks good so I am thinking maybe a idler pulley but who knows..........
Old Jan 26, 2004 | 02:18 PM
Durien's Avatar
i spilled coolant on mine once and it ruined the belt..lol..it wouldnt stop squeaking no matter what
Old Jan 26, 2004 | 03:14 PM
Silver6sp's Avatar
yea coolant will make a belt go bad, but if you sprayed it will something and it went away that does indicate a bad belt but double check that all of your pullies are aligned and the belt is not walking
Old Jan 27, 2004 | 04:50 PM
WILWAXU's Avatar
Is it the belt making the noise or the idler pulley?
Old Jan 27, 2004 | 10:16 PM
FatZ28's Avatar
I had the same problem. Ended up being the idler pulley.
