Old May 18, 2016, 06:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
spark plug wires
Old Sep 10, 2010 | 02:12 PM
Seit's Avatar
0.1tenth = 10% of 1tenth
The gain is almost zero
So if you have little money, the better your buying another brand of low cost
Old Sep 10, 2010 | 02:44 PM
Element's Avatar
My "lolwat" was at your recommendation that he waste almost $800 on a set of MSD coils that, at best, won't do ****.
Plug wires are plug wires, switching from stock to MSD won't result in more power or faster times. On a regular engine with a distributor and some long plug wires? Maybe, debatable. On coil-on-plug with 6" wires? Not unless the stockers were brittle and cracked.
Old Sep 10, 2010 | 04:58 PM
dwfronk's Avatar
Ok well since this is such a hot subject. I am in need of some new wires and if i can get a more consistant good spark from spending a little more on some good wires then i will. And im not compleatly stock i java e a lq4 swap.
Old Sep 10, 2010 | 06:59 PM
NVR_SPDS's Avatar
I run MSDs on both our cars, and dont have any complaints at all. i got black ones on our black car, and red ones on our SOM car.
Old Sep 10, 2010 | 07:23 PM
HoLLo's Avatar
The only reason I like MSD's is the coating is super thick. Hard to burn/melt
Old Sep 10, 2010 | 09:02 PM
legendarysouls's Avatar
newbie question
whts the difference between NGK TR55 or TR6's
Old Sep 10, 2010 | 10:20 PM
RedRallyeZ's Avatar
Originally Posted by legendarysouls
newbie question
Tr6's are one step colder plug
Old Sep 10, 2010 | 10:27 PM
ULTIMATEORANGESS's Avatar
i have an $80 set of borg warner wires on my car.
Old Sep 10, 2010 | 10:44 PM
HoLLo's Avatar
newbie question
TR6's are a "colder" plug, meaning the spark isn't as hot, typically also having a smaller gap on the plug. Better for nitrous and boost applications. They also have TR7s for big shots of N2O, or high boost.
Old Sep 12, 2010 | 09:12 AM
FastKat's Avatar
I got a set of GM AC Delco crate motor take offs from flea bay. They were advertised, look, and work like new. I got a good deal on them too.
If I was going ***** to the wall and/or needed something that would resist very high temperatures, I would buy Magnecor.
Old Sep 12, 2010 | 12:53 PM
RedmaroSS's Avatar
8mm Taylor....Been running them for years and have very good luck with them i love the wires and they are good with high heat so no problems with the headers, you can bend/manuver them a little dont know as to if more than an MSD
Old Sep 12, 2010 | 03:49 PM
  #32
X-ray's Avatar
The original wires, runs great.
