Meziere race pump ??
Here are some half *** instructions. Good lick
Tom
I have the race only also. I fought with the altenator for a day or so and then found the solution. The altenator and altenator bracket stays in the stock location. I installed the tensioner pully in the idler pully location located on the altenator bracket. The altenator bracket needs to be modified a little to achieve this which means grind off some of the bracket support in that location. You'll see. You will use only 1 bolt to bolt on the tensioner pully. The tension from the belt will hold the pully in place. The belt size is 37". You will also need to grind off a portion of the lower bolt head so the belt does not rub. That's it. It works great. I'll e-mail you a pic if you are interested. This mod works great.
Tom
J/K Did you go get that car and new trailer yet???
and yes I have a 28' trailer. Im going to pic it up saturday if we don't have another snow storm. Zip file
I owe you one
Granny, I'll e-mail you a pic. Post it up if ya want to.
You welcome Brian, anytime.
Tom
I cant wait to put it on too,but I have a street car and I need heat
U race guys are too hardcore for me...
JS
Looking for the 10's.....
JS
Use an electric heater
Jegs sells them
No adjusting required
My belt goes around the balancer, alt. and tensioner. JMO
Tom
Mine is different. I have a motor plate now and Madman fabed up a great alt. set up with one belt. My Alt is now in a different location.
This is a RACECAR set up only.
Coach
Coach
I can see how adjusability could easily be accomplished with a motor plate. I have one of Madmans motorplates too but I never installed it because you need a mid plate too. I get to it one of these days I guess. Anyone want to purchase a brand new Madman motor plate? $100 shipped.
Tom
Tom
Coach
Tom
Interesting, Madman didn't put in a mid plate. I just have the motor plate installed. It looks very nice with the new ewp. I will try to post up some picks soon. It is still wrestling season and it is hard to do anything else right now.
Coach
