Bosch or Denso?
Old Sep 14, 2010 | 09:40 PM
White94Bird's Avatar
Default Bosch or Denso?
I'm in need of new os sensors because my LTs fried my factory ones.
what do you guys recommend, I've read that 13111 are good but can throw some codes
Old Sep 14, 2010 | 09:46 PM
badbird5.7's Avatar
i use Delphi's or AC Delco's
Old Sep 14, 2010 | 09:49 PM
Part #?
Old Sep 14, 2010 | 09:53 PM
badbird5.7's Avatar
i'll get it for you when i get off work, i've always had great luck with these ones
Old Sep 14, 2010 | 09:59 PM
libertyforall1776's Avatar
Looks like Denso is better, some notes on them on Camaros here:
http://www.camarohomepage.com/project/part3.htm
Denso is stock in some GM cars...
"The Denso "O2S" is better because its aluminum-oxide "trap layer" covers the sensor element and resists damage to its platinum electrode and a porous, PTFE (Teflon) filter on the sensor's atmospheric side prevents moisture or contaminants from degrading accuracy."
Top is Delphi, Bottom is Denso:
Old Sep 14, 2010 | 10:49 PM
beedo's Avatar
Got a brand new Bosch for 50.00 if you decide to go that route.
Old Sep 15, 2010 | 03:44 PM
Autozone says that there is a difference in the left and right side? The Denso are more expensive for the right side?? What gives?
Old Sep 16, 2010 | 11:44 AM
Bad Blu Formula's Avatar
There shouldn't be a price differece. Its the same part. Autopart stores are so dumb sometimes.
Anyway, I run the Denso sensors on my car and they've done better than the Bosch's ever did.
Old Sep 16, 2010 | 01:17 PM
HAZ-Matt's Avatar
They aren't the same part. They have different length tails on them.
As far as not giving codes, I have been able to run the Delphi O2's without insufficient switching codes, although I would get the code with brand new Densos. As said above, if you order an AC Delco replacement nowadays you will get a Denso. Most don't care about that code and just turn it off.
Haven't used a Bosch on my car.
Old Sep 16, 2010 | 02:31 PM
bene's Avatar
Trunion King
I've tried both Denso and Delco brands. Both identical and both got me the insufficient code. Denso did only last for a few months. I am now trying the NGK/NTK brand O2s and hopefully they are better.
Old Sep 16, 2010 | 06:14 PM
By tails you mean the wire length, right?
Old Sep 16, 2010 | 08:41 PM
01'SSLSX's Avatar
i use bosch 13111, and i've never had a problem with them. im a cam only car that made 390hp on a mustang dyno.
also i have a friend at a parts store so i got my o2's for like $50 a piece.
regularly i think their $70
Old Sep 16, 2010 | 08:53 PM
HAZ-Matt's Avatar
Yeah, the wire length. I have extensions so for me I can just get a pair of what is cheaper since the short ones reach. People like the post cat Vette sensors since they have really long tails and you don't need an extension.
Old Sep 16, 2010 | 09:12 PM
MillerTime85's Avatar
I've always heard good thing's on the denso's.
Old Sep 16, 2010 | 10:32 PM
Damian's Avatar
LSX Mechanic
Neither.
NGK is the way to go. I've tested them all back to back while tuning cars. The NGK's are 2-3% more accurate, every time.
Old Sep 17, 2010 | 03:19 AM
King Nothing's Avatar
13111's here also and i haven't run into any problems yet but all i have is LT's
Old Sep 17, 2010 | 05:34 AM
justinj's Avatar
Originally Posted by Damian
Neither.
what's the part number?
Old Sep 17, 2010 | 07:26 AM
Well I ordered 2 Densos and only paid $84.xx for the pair, great deal!!
I'll see if these work any better.
Old Dec 20, 2010 | 08:29 AM
I have about 4000 miles on them and they are working great, got a slow response code and deleted it and it never came back.
I'm satisfied for now..
Old Dec 20, 2010 | 10:23 AM
LS1121's Avatar
I got a pair of Bosch 13444 for $29 New off of Ebay, the wire was a little long on the driver side so I used a plastic wire tie. They are working fine for 2 weeks now. I know what people say but $29 was hard to pass up.
