ls6 intake help
Old Sep 21, 2010 | 07:50 PM
duesmandella's Avatar
I took the vacuum line and plugged it onto a bolt top over the coil packs on the driver side.
Old Oct 31, 2010 | 10:31 AM
legendarysouls's Avatar
Default ONE quick Q
Are the Air and Egr block plates interchangeable?
and which intake gasket do i need?
lookin at this one Weiand 108-117 from jegs or can i get the seprate 8 ring ones?
Old Oct 31, 2010 | 10:10 PM
Tobias05's Avatar
block off plates are not interchangeable. speed inc sells the plate kit, AND the felpro gasket kit for these parts.
order felpro ms92438 intake gaskets.
I'd personally order new fuel injector o-rings while you've got it all apart also.
Old Nov 1, 2010 | 12:29 AM
70hemicuda's Avatar
instead of chipping your intake manifold apart, just tap down the coolant lines with a hammer. they're soft
