AC only blows at my feet and the vent???
Old Sep 19, 2010 | 09:24 PM
charlie c5's Avatar
Default AC only blows at my feet and the vent???
Working on a 2002 WS6. Did a motor swap, and pulled the tranny and turbo off the car, and now for some reason the AC only blows at my feet and the top vents. Whats the deal. I double and tripple checked the little vacuum line on the rear of the intake. Any suggestions guys. The car only has 39K miles. Do I need that little vacuum "T".? Can I take it out and run the vacuum line from the intake into the car..?
Old Sep 20, 2010 | 08:58 AM
Steve Gunn's Avatar
The vacuum line that you triple checked should be the only culprit I'm aware of that an engine swap would effect? Good luck!
Old Sep 20, 2010 | 10:49 AM
mike171562's Avatar
there is a little T-fitting right by the PCM, it cracks easily, had to replace mine.
Old Sep 20, 2010 | 12:47 PM
sscamaroburn02's Avatar
yeah the only think i can think of is maybe its cracked or something. mine did same thing just forgot to reconnect the vacuum line.
Old Sep 20, 2010 | 07:58 PM
charlie c5's Avatar
Old Sep 20, 2010 | 08:28 PM
HoLLo's Avatar
One time my old 97 only blew air to my feet, I pulled the AC controls in the dash and noticed a line behind the controls was unplugged. Plugged it up and it worked fine..
Old Sep 21, 2010 | 08:47 PM
charlie c5's Avatar
Fixed!!! Damn, I looked and looked and couldnt find anything wrong. But, I pulled the line off of the back of the intake and replaced the whole line from the intake to the firewall over behind the pcm, and started the car and damn, all fixed... Woohooo. Thanks guys..
