Radiator manual/automatic trans???
Old Sep 22, 2010 | 08:08 PM
disavowed10's Avatar
Default Radiator manual/automatic trans???
Hey guys im trying to replace my radiator and i have a manual trans..
i remember awhile ago i bought a radiator from autozone or sumthing it was supposed to be a universal of some kind but there was an inlet that didnt go to anything.. /??
this is the autozone link:
http://www.autozone.com/autozone/par...uestid=1841499
thanks for the help guys
Old Sep 22, 2010 | 08:49 PM
csv033's Avatar
Hey mate,
Im not sure that is the correct image but if you read down lower
Quote "Transmission Oil Cooler: 11 1/2 in. (4 plate)" So its an Auto Radiator.
So it has an inbuilt oil cooler are these the extra things your refering too?
Regards Rory
Old Sep 22, 2010 | 08:58 PM
eseibel67's Avatar
You can use an auto trans rad in a manual car. Just disregard the cooler by leaving the plugs in.
Old Sep 23, 2010 | 12:19 AM
hey guys thanks for the response.
do you see in the lower left area of the radiator that little inlet/outlet?
what does that go to?
thanks for the support
Old Sep 23, 2010 | 12:31 AM
bearcatt's Avatar
That radiator in your link is actually a picture of a LT1 radiator.
That bottom left outlet is for the steamport that connects underneath the waterpump of a LT1 engine, LS1 cars don't have that.
Also on the righthand side there is a small hole for the coolant level sensor.
LS1's do not use a coolant level sensor either.
I recently replaced my old LS1 radiator with a new LT1 radiator like the one in your link. I blocked off both of those holes. The reason I used the LT1 radiator is because it is a little thicker than the original LS1 radiator.
Many LS1 owners upgrade thier radiators with the LT1 radiator, SLP used to sell a modified LT1 radiator for about $300 .
Old Sep 23, 2010 | 01:23 AM
KCFormula's Avatar
Also (to add to bearcatt's post) all LT1s got the same radiators, manual cars just had block offs in the radiator for the trans cooler.
I used to have the dims of the LS1 vs LT1 rads, I think the LT1 was like 5/8" thicker, maybe not that much but it was a significant amount.
Old Sep 23, 2010 | 12:47 PM
hey thanks so much for the help guys!
what can i use to block the inlet on the lower left??
seems like there would be alot of pressure so something tough?
thanks again!
Old Sep 23, 2010 | 04:46 PM
SOMbitch's Avatar
My original LS1 radiator had a low coolant sensor and my Howe Racing radiator has the fitting for it.......
Old Sep 26, 2010 | 11:36 AM
any ideas guys on what i can use to block off that 'extra' inlet?
Old Sep 26, 2010 | 02:16 PM
bearcatt's Avatar
I got creative and used small a piece of PVC pipe, a plug and a cap.
I had to grind and dremel to make them fit. Then I used some flat black paint
over those areas. I wanted the results to look like it came from the factory.
The epoxy I used was locktite marine. You have to mix the epoxy good when applying and let it cure.
http://www.loctiteproducts.com/p/13/...tic-Bonder.htm
http://www.loctiteproducts.com/p/13/...oxy-Marine.htm
So far so good, it's been a little over a month.
Old Sep 26, 2010 | 02:26 PM
Ruthless909's Avatar
JB weld is your friend as well.
