Tips on Installing headers..
Old Jan 27, 2004 | 11:55 PM
1F8TL02WS6's Avatar
Default Tips on Installing headers..
Got any tips on installing headers. I know about the dropping the K-Memeber a few inches, but what are some other ones. About to install some hooker long tubes. thanks guys
Old Jan 28, 2004 | 12:02 AM
RAMnGO's Avatar
not sure about Hooker, but with my SLP's i had to take off the oil filter,starter, and redo some wiring on the passenger side as well or at least i did, and if at all possible use a lift. i put mine on using 2 jackstands and it sucked big time. Also your hands will thank you ALOT if you take the coil packs off. You'd be surprised how much clearance they gave me..and thats about all i can remember at this time....hope it helps some
Old Jan 28, 2004 | 12:04 AM
jd13's Avatar
I installed Kooks not long ago.
Removed: coil packs, plugs and wires, oil filter, steering
Trick to getting the driver side in: Had to unbolt the motor mount and jack up the engine approx 2 inches.
I really don't think you'll need to drop the k member. I'd do that as a last resort.
Old Jan 28, 2004 | 05:23 AM
Slowhawk's Avatar
LS1Tech Sponsor
Hookers slide in easy without disconnecting anything.If your doing it on the ground you just have to jack the car really high to get the driver side in.
Old Jan 28, 2004 | 05:56 AM
foff667's Avatar
LS1TECH Sponsor
check out my sig for my pacesetter install im sure its just about the same as hooker
lata
Bill
Old Jan 28, 2004 | 11:40 AM
Steve Burger's Avatar
LS1TECH Sponsor
Hookers are easy. I put the car on cinder blocks. Open part of the block under the tire. The passenger side just goes in. The drivers side needs the steering linkage, oil filter and oil diverter plate removed. After that it just goes right in. The cinder blocks lifted the car up enought to make this easy and only cost $4 at Lowes.
Do not use the Hooker supplied bolts, use the factory bolts. Other than that it is a peice of cake.
Old Jan 28, 2004 | 12:10 PM
TaTommyWS6's Avatar
Tommy's Tip:
Make sure you clean the bolt holes with the proper tap, and use anti-seize while reinstalling the bolts. Residue in the bolt holes could cause troubles while reinstalling the bolts, alumunim is not so fun all the time.
Tommy
Old Jan 28, 2004 | 01:22 PM
Jammer's Avatar
QTP's slide them in, but have patience to wiggle push and curse, but they do go.
Old Jan 28, 2004 | 09:19 PM
cm02WS6's Avatar
Originally Posted by TaTommyWS6
Tommy's Tip:
Tommy
What is the tap size?
Old Jan 28, 2004 | 10:29 PM
NVDZ28's Avatar
I had to do exactly what he said.......I had a lift which made it much easier...
Old Jan 28, 2004 | 10:46 PM
StevieZ's Avatar
Kooks will go on without jacking the motor on either side.
Old Jan 28, 2004 | 10:50 PM
PurdueWS6's Avatar
with hookers u will probably only have a problem with the steering link but thats about it, other than that mine fits good
Mahmood
Old Jan 28, 2004 | 10:52 PM
LS1999pewterZ's Avatar
What about SLP LT's how do they fit?
Old Jan 28, 2004 | 10:59 PM
Ferocity02's Avatar
And what about TTS...
Old Jan 28, 2004 | 11:35 PM
1F8TL02WS6's Avatar
thanks alot guys, now, what about taking out the !egr, !air **** like that, that removes when u put the headers in is all of that just self exsplanatory. Im trying to get as much info as pissible before diving into this on my next day off.
Old Jan 29, 2004 | 09:04 AM
CamaroCain's Avatar
oh i know, i know....what about doing a search in this forum
Old Jan 29, 2004 | 09:18 AM
TaTommyWS6's Avatar
I believe it is a 8MM X 1.25
Tommy
Old Jan 29, 2004 | 11:21 AM
SSN8R's Avatar
All we did was drop the tranny cross member bolt and have a buddy grab the back of the tranny and move it away from the side you are slipping in. It doesn't move much, but it is enough.
Did not have to remove the starter, oil filter, steering link, etc. They fit perfectly.
Good Luck,
Old Jan 29, 2004 | 11:23 AM
Durien's Avatar
all i can say is have fun and be patient...
Old Jan 29, 2004 | 01:13 PM
LS1TECH Sponsor
Tap size is correct I know that from experience. I tried to use the Hooker bolts first. It is an odd size and you wil need to get this from and auto parts store.
