Nology hotwires wtf!!!!!
a capacitor is basically a pair of conductors separated by an insulator;
a capacitor blocks DC signals and passes AC/pulse signals between the plates;
a capacitor couples the plates via the electric field between the plates (for AC/pulses only).
Now, after viewing the pics posted above, these are my $0.02 comments:
there are TWO separate things going on here...
the "capacitor" would leak some of the ignition pulse to ground via electric field coupling (i.e. the ignition pulse would lose some energy);
the tightly wound spiral conductor leaks very little magnetic field... the magnetic field pretty much cancels out any at appreciable distances external to the wire (compared to the diameter of the spiral), as long as the spiral is wound very tightly (i.e. a few inches compared to 1/16th inch)... (this is because the magnetic field created by current in a spiral is balanced by an opposite magnetic field on the other side of the spiral); the almost zero external magnetic field means almost zero energy is lost via magnetic field coupling (electromagnetic induction) to surrounding conductive objects.
so my from my understanding, that wire loses some energy via capacitive coupling, but loses almost zero energy via inductive coupling; you may be able to measure this using some form of electroscope (measures electric field);
other than that, I can't see what the purpose of the "capacitor" is.
$0.02
I'm thinking these wires are the same thing. RF guy looked at the picture, laughed, and said "Marketing".
/shrug
/shrug
