Which heads?
Old Sep 28, 2010 | 10:23 PM
VandykeT/A's Avatar
Default Which heads?
Well with Christmas coming up and I get a financial aid check from college I'm gonna try to get some heads. I know the Trickflows are the best but with needing roller rockers and all that would there be a cheaper solution that would give similar gains?
Old Sep 29, 2010 | 10:06 AM
garygnu's Avatar
you can use stock rockers with trick flows,you need to shim them correctly.get some trunnion bearings for the rockers.you will need longer push rods too.
Old Sep 29, 2010 | 10:10 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
Our PRC 215cc heads are a comparable aftermarket casting head which does not require aftermarket rockers to work correctly. The heads will feature the thicker aftermarket casting, 13.5 degree valve angle, 2.04" intake and 1.60" valves, and a 62cc chamber to start with. By the time christmas rolls around we might even be offering a sale on them.
Old Sep 29, 2010 | 10:36 AM
black06g85's Avatar
good cause I"ve been eyeing those for my mild build for the spring.
Old Sep 29, 2010 | 12:06 PM
SSmoken's Avatar
i used the shim / pushrod kit from thunder racing and stock rockers on my tfs heads.
Old Sep 29, 2010 | 12:48 PM
GTOdave's Avatar
depends...what cam you got?
Old Sep 29, 2010 | 05:00 PM
VandykeT/A's Avatar
Torquer 2
Old Sep 29, 2010 | 08:21 PM
GTOdave's Avatar
i see my buddy has that cam and stock ls6 heads and intake and it runs pretty good..those are good heads for the money.
Old Sep 29, 2010 | 08:47 PM
VandykeT/A's Avatar
whats the stock combustion chamber size on a 02 LS1? I think I've got 241s
Old Sep 29, 2010 | 10:12 PM
massls1guy's Avatar
Using a financial aid check from college to buy heads sounds like a bad idea. I think that means I'm getting old.
Old Sep 29, 2010 | 10:33 PM
VandykeT/A's Avatar
It probably is a bad idea lol
Old Sep 29, 2010 | 11:06 PM
SOMbitch's Avatar
***** it you only live once I say.....If you want it bad enough do it... JUST DON'T DO IT HALF *** OR YOU WILL REGRET IT!!! GET IT RIGHT THE FIRST TIME!!!! Trust me on this.... and when you are married and older you can forget it because ***** RULES THE WORLD!!!! Unless you make 6 figures she will be the boss...and even the she may still be the boss....
Old Sep 30, 2010 | 11:41 AM
GTOdave's Avatar
241s are a 66cc i think..if i was you i would get 243s then maybe port them out later
