magnaflow cat back ??'s
thanks
http://www.youtube.com/watch?v=snzFQ37L0yY
http://www.youtube.com/watch?v=A93Usspajh8
ok, just thought i would update on the magnaflow, just installed pacesetter cc long tubes, and ory. This really woke the beast. sounds great!! I was a little worried with the magnaflow and stock manifolds cause it wasn't what i was looking for, but now, holy **** what a difference! so, gona put it on the dyno at rpm in garner this monday and get it tuned to spray 150 i hope. what do you think it will put down?
http://www.youtube.com/watch?v=sqr4Tf8sKKM
thanks
As for the car falling on its face, I didn't have that problem. Drive it a little and see if it clears up. I added the Magnaflow with a lid and didn't notice much of a difference other than sound.
Is the car throwing any codes? Can you get it scanned to check for any stored codes?
Try driving it for a couple days...ECU probably needs to relearn a little bit since you unhooked the battery. You could also double-check to make sure you didn't inadvertently pull any wires out of the front O2s swapping exhaust setups.
"What a *****".........but a year later LT's & no cat's & I love how it sounds!!
