Water pump leaking from back panel???
Old 10-16-2010, 03:13 PM
Marcello7x's Avatar
Default Water pump leaking from back panel???
I'm maybe hours from my first start up on my 5.3 and notice a leak once i filled up with a good amount of coolant. Seems to be coming out of that bolted on panel on the back of the water pump. The pump came with my motor, 57K on it.
Anyone ever get a leak from there??? Man am i pissed, i've been dyin to get this car going and now another setback.
Old 10-16-2010, 06:12 PM
sjsingle1's Avatar
not much of a gasket on the rear cover if i remember correctly.....seems all the rubber type gaskets on the engine are crapping out on me.......leaks everywhere....just replaced the intake gaskets....they were shrunk and hardened
Old 10-16-2010, 06:14 PM
Marcello7x's Avatar
I have brand new pump to block gaskets. Leak slowed since i posted, but i bet its cause theres not much left in that chamber of the pump to leak.
Old 10-17-2010, 08:17 PM
rabbit320's Avatar
yes ive had the same problem, leaking from behind the center pulley. new pump from advance auto for pretty cheap.
Old 10-20-2010, 04:41 AM
71ANTICARB's Avatar
Did you get your new pump yet.
