Professional Products Typhoon 96mm?
Old Jan 22, 2011 | 09:27 AM
1998silverbird's Avatar
Any more news on these? I am looking at a 96 mm LS1 style with the LS2 style TB..
Old Jan 22, 2011 | 11:42 AM
BennyB's Avatar
when i was in the market for an intake i took the typhoon into consideration. Its a third of the price of the fast intakes and the performance is there. In the end i ended up going with a painted ls6 intake, but i really wish i would have ended up going with the typhoon. What kept me away were some of the OLD reviews of the older style which did have problems sealing, but since then they have taken care of that problem. I also really liked the intake because its different and not many people run them. Oh and it looks good too
Old Jan 22, 2011 | 10:46 PM
mikey1107's Avatar
http://www.professional-products.com...ests/52060.pdf
I found this on professional products website
Old Jan 22, 2011 | 11:30 PM
aaronware76's Avatar
any comparissons to the 85mm bbk intake? i had the older pp typhoon a few years ago and i had a problem with it sealing, took it off and went with the bbk. now that they've corrected that problem, i'd be interested in trying the 96mm. i want more power for my H/C setup but dont have the dough for a fast 92 or 102.
Old Jan 24, 2011 | 08:35 PM
venom13132's Avatar
as soon as my tax refund comes in I am going to order the LS2 cable driven 96mm throttle body. I have the intake manifold and it looks great. I am going to powder coat it before putting it on. I have a lot going on with my car before I test it out with the new intake though.
Old Feb 7, 2011 | 08:29 PM
venom13132's Avatar
here are a bunch of pictures of it all
[/QUOTE]
Old Feb 8, 2011 | 07:03 AM
SOMSS's Avatar
Think about using a ported LS2 TB with a ported LS2 intake, one third the cost of a FAST. It will perform nearly the same, you could even convert to Drive by Wire. I am doing this conversion now. Don't have the LS2 intake yet, it's being ported and painted now.
Old Feb 8, 2011 | 11:24 AM
LS1-IROC's Avatar
Wow...didn't realize you got fuel rails at that price too...that seems like a great deal especially when you look at what they charge just for the rails.
Old Feb 8, 2011 | 01:49 PM
24/48's Avatar
Also guys Speed Inc. now sells these, which makes me feel alot better about the intake and TB.
Old Feb 8, 2011 | 02:40 PM
bayer-z28's Avatar
[IMG]
I've read that the LS2 intake is a turd. That's prolly why no one really talks about it. LS3 intake on the other hand is supposed to be really good, but that doesn't help us much. A lot more goes into an intake than just the TB size. That, alone, doesn't make the intake.
Old Feb 8, 2011 | 09:11 PM
venom13132's Avatar
yeah for the money and the performance you really cant beat it.
I paid $345 shipped for the intake and rails and $230 shipped for the Throttle body.
Old Feb 9, 2011 | 08:50 AM
  #32
Crashz28's Avatar
Im really interested in trying this intake also looks nice way better priced than the fast and it comes with fuel rails how do the ports look inside are they finished up nicely are there any ridges inside them have you matched the intake up to the heads to see how well everything lines up??? I wonder how much of a difference it will make over a ls6 or a bbk intake???
Old Feb 9, 2011 | 11:08 AM
  #33
Capricio's Avatar
That TB looks like a monster! Can't wait to put mine on now. I paid $230. If it works well at idle and doesn't surge, I'll be happy.
I am using a ported LS2 intake off a crate engine that came with injectors, rails, gaskets, and a DBW TB (for sale). Got a cable bracket from Holley, EV1 to EV6 adapters, coolant pipes/plugs, MAP ext. I think I have it all covered.
I've read two other threads this week that say if you have ported heads, you almost can't over size your TB, unlike the old carb days where fuel atomizing was affected.
Will my LS2 intake sit on my valley cover with stock LS1 bolts? Or do I need the low profile ones that someone mentioned earlier?
Old Feb 9, 2011 | 08:24 PM
  #34
redneckcritter's Avatar
I have a question I have a 6.0 truck motor from a 03. I am also looking at this intake but not sure if it will fit my heads? Does any one know.
Old Feb 10, 2011 | 05:46 AM
  #35
venom13132's Avatar
Manifold
http://cgi.ebay.com/ebaymotors/ws/eB...=#ht_500wt_868
TB
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2838wt_854
Old Feb 10, 2011 | 09:54 AM
  #36
LS1MCSS's Avatar
One thing to watch out for when you install that intake. The gaskets have extra large holes where the bolts go through. They don't use o-ring style gaskets. With the large holes, the gasket can slip to one side real easy. This will cause a vacuum leak so bad that the car will never run right. It most likely wouldn't even start, the leak would be so bad.
Old Feb 11, 2011 | 01:09 AM
  #37
cowboysfan's Avatar
here is my PP intake!!!!
http://www.streetfire.net/video/prof...old_721631.htm
Old Feb 11, 2011 | 09:24 AM
  #38
bayer-z28's Avatar
I'm out.. Bought a 102.
Old Jun 21, 2011 | 11:39 PM
  #39
venom13132's Avatar
I just started installing mine tonight. (just got my engine back today)
Ill get some better shots of it tomorrow once I get it all together and bolted down properly.
Old Jul 13, 2011 | 08:18 PM
  #40
venom13132's Avatar
quick update. I shortened the cross over pipe so it does not stick up so high. I also ordered a new throttle cable and throttle cable bracket from Jegs got the Lokar 3' cable and bracket that has the hole for the cruise control because the one with out cruise would require a spacer. Plus I have to drill and tap the holes for the throttle cable. I am doing that tomorrow night and getting everything buttoned up so I will post pictures tomorrow night once i am done.
I also ordered a 4 1/4" to 4" 90 degree elbow for my intake. I decided to get an LS7 MAF and adapter cable because it did not make sense to me to go from a 4 1/4" Throttle body down to a 3.5" MAF. so that will be interesting..
