Professional Products Typhoon 96mm?
Old Jul 14, 2011 | 11:16 AM
  #41
themealonwheels's Avatar
Originally Posted by venom13132
quick update. I shortened the cross over pipe so it does not stick up so high. I also ordered a new throttle cable and throttle cable bracket from Jegs got the Lokar 3' cable and bracket that has the hole for the cruise control because the one with out cruise would require a spacer. Plus I have to drill and tap the holes for the throttle cable. I am doing that tomorrow night and getting everything buttoned up so I will post pictures tomorrow night once i am done.
I also ordered a 4 1/4" to 4" 90 degree elbow for my intake. I decided to get an LS7 MAF and adapter cable because it did not make sense to me to go from a 4 1/4" Throttle body down to a 3.5" MAF. so that will be interesting..
I'm very interested to see how you get the throttle cable setup figured out. I installed the PP 101mm TB on a 96mm Typhoon, only to find that the cable was WAAAY off (more than an inch) from the stock bracket guide and the cable was short, holding the throttle about halfway open! Please post pics
Old Jul 15, 2011 | 02:56 PM
  #42
venom13132's Avatar
i got it done. no issues with the throttle cable but I have this all installed in an RX7 and I am not using a stock throttle cable. Using the Lokar 3'cable and lokar throttle cable mount.
Old Jul 16, 2011 | 10:35 PM
  #43
garygnu's Avatar
how far out can the TB opening be ported?how good is the port alignment?dose the intake have a bottom plate that can be removed for internal porting?
Old Jul 17, 2011 | 06:21 PM
  #44
venom13132's Avatar
i dont know much about porting so not sure
Old Sep 18, 2011 | 12:58 PM
  #45
roninsonic's Avatar
I'm interested in this as well... I'm considering buying a typhoon 96 with a big throttle body, but I'm not sure if I'd be able to keep my cruise. Also, what elbow and maf did you go with?
Old Sep 19, 2011 | 08:10 PM
  #46
venom13132's Avatar
I went with a 4 1/4" to 4" 90 degree elbow and no maf
Old Sep 21, 2011 | 01:15 AM
  #47
blocc monster's Avatar
i keep my cruise.
Old Apr 19, 2012 | 03:29 PM
  #48
mad max motorsports's Avatar
I am looking at these also, but for mild stroker + turbo. Plastic + boost scares me alittle.
Old Sep 9, 2012 | 07:02 PM
  #49
djsanchez2's Avatar
Originally Posted by cowboysfan
Did you ever re-dyno it? I think we would all be interested in some numbers.
Old Jan 6, 2013 | 01:06 PM
  #50
Khipset's Avatar
Originally Posted by jimmyblue
The one thing to watch is the gaskets, the early production
ones tended not to seal well and they were updated to an
embossed-O-ring design. Green colored fiber ones are old.
Pro Products was kind enough to send me the new type.
You will want to replace the valley cover bolts with low
profile button head screws.
Can you install the Professional Products manifold using any o-ring design gaskets such as the Victor Reinz MS19430 or do they have to come from Professional Products?
Old Feb 22, 2014 | 10:35 PM
  #51
ez2cdave's Avatar
Yes, it's over a year ago . . .
Any answers about being able to use a gasket, other than the ones from Professional Products ?
Old Apr 19, 2014 | 05:00 PM
  #52
ez2cdave's Avatar
Any info on this ?
Old Jan 11, 2016 | 09:31 PM
  #53
54inches's Avatar
Anyone else still have their car and still running this intake?
Old Jan 12, 2016 | 06:01 AM
  #54
MonmouthCtyLS7's Avatar
I ran the 85mm setup for years. Overall the design was terrible, it was heavy as **** along with having several leaking issues. If you don't want to spend the dough on a Fast setup I recommend just running a LS6.
Old Jan 12, 2016 | 01:16 PM
  #55
jimmyblue's Avatar
Moderator
Still have my 85mm, no issues. Do not know about other
gasket sources but since the intake still has to fit stock
heads I'd expect general compatibility. Thickness though
may matter.
Old Jan 13, 2016 | 09:49 PM
  #56
54inches's Avatar
may matter.
How heavy is it?
Old Jan 14, 2016 | 06:12 AM
  #57
ULTIMATEORANGESS's Avatar
is this part still available?
Old Jan 14, 2016 | 08:53 PM
  #58
omc8's Avatar
Originally Posted by 54inches
How heavy is it?
If iirc it adds 12lbs over over the composite oem intakes.
What part the Typhoon intake ? Yes there still selling them .
