Pace 85mm MAF install problem
Old Jan 31, 2004 | 07:33 PM
Damage Inc.'s Avatar
Sweet Cheeks
Default Pace 85mm MAF install problem
I ordered a Pace 85mm LS6 maf for my Z28 and I got it today. I was about to install it when I realized that I need an 85mm lid too. I ordered the lid from TSP, but check this out:
The MAF came with a wiring harness, but the connectors are funny. The 3 wire LS1 to 5 wire LS6 is fine, but the IAT plug just plugs into the stock IAT connector and not in the lid like before. Is this right? Does the 85mm MAF delete the IAT lid sensor? I need help. I noticed that TSP sells their 85mm lids with or without the IAT hole. Is this because it's deleted by the 85mm MAF? Someone please clarify.
The directions from Pace say 1997-2001 Corvette Y body on it. Did they send the wrong unit? Or are they just the same directions?
Old Jan 31, 2004 | 09:41 PM
cueball's Avatar
yes you can do it both ways, you can plug it in the maf conector, or in the stock IAT conector, its up to you
i would just plug it in the maf conector, and since you have to get a 85mm lid
i would get the one with out the IAT port.
Old Jan 31, 2004 | 10:02 PM
2001 Pewter WS6's Avatar
Restricted User
Use the IAT sensor in the lid. You want it located as far from the engine as possible to get it away from the heat.
Old Feb 1, 2004 | 02:46 PM
Sweet Cheeks
Ok thanks. I thought they sent me the wrong MAF for a second. Ha.
Old Feb 1, 2004 | 07:21 PM
jimmyblue's Avatar
Moderator
I believe the in-MAF IAT sensor is superior to the lid,
because it's in the true air stream. With my lid-mounted
one there is substantial sensor heat soak; it takes
quite a while (many minutes) to come to ambient temp
although the inlet air on my car is about as fresh as you
can get. This is due I believe to it being located on the side,
away from airflow, and poorly "connected" to the actual
inlet air stream.
The bigger MAFs are all plastic housings and heat soak is
overwith after a couple seconds' running, as far as the
in-stream thermistor is concerned.
This a "one of these days" mod for me, to eliminate the
adaptor harness and bring the IAT wires to the SLP MAF
connector cleanly.
Old Feb 1, 2004 | 08:23 PM
cueball's Avatar
inlet air stream.
connector cleanly.
i agree, pluss the lid is over the radiator and more prone to heat soak.
plus you could just solder in a 1k ohms resistor in series with the iat sensor if needed, makes a big diff. if heat soak is a problem
