Is there a way to clean 02 sensors?
Old Feb 1, 2004 | 10:04 AM
NOTFAST's Avatar
Default Is there a way to clean 02 sensors?
I took off my rear and they have just been sitting in my garage.
Now my fronts are bad, so I was gonna switch them out.
Can I clean the rear ones? Maybe I will shoot them with that canned air stuff you use to clean computers.
Old Feb 1, 2004 | 10:22 AM
Bad30th's Avatar
I've heard you can use a torch to clean them by heating the end up.
I wouldn't think compressed air would do much to clean them.
Never tried the torching method myself, new ones are $60 at AutoZone.
Good luck,
Bad30th
Old Feb 1, 2004 | 11:09 AM
NOTFAST's Avatar
I guess a torch would be good, burn off the excess carbon, and built up **** on the end.
Old Feb 3, 2004 | 06:58 PM
WILWAXU's Avatar
If there's not a ton of miles on them.. I'd just bolt them in.
Old Feb 4, 2004 | 12:59 AM
onyxxtreme's Avatar
I was always told to clean them with isopropyl-alcohol
a few of my RX7 friends have been doing it for years without problems
their O2's get dirty quick, cause rotary's typically burn oil like Oprah eats cheetos
Old Feb 4, 2004 | 05:25 AM
SSactionLs1's Avatar
couldnt brake cleaner do it?
Old Feb 4, 2004 | 06:22 AM
2001 Pewter WS6's Avatar
Restricted User
That is what I did. Mine were black from running really rich. I sprayed them down with Brake Cleaner and wiped them off. They work fine...
