Header Removel need help
Old Oct 28, 2010 | 06:03 PM
SScamaro4's Avatar
Thumbs up Header Removel need help
I have an ls1 with longtubes on. I didn't install them myself my school did big mistake. I heard you have to yank the steering shaft , but it looks like it hits the motor mount because it clears the steering shaft.
Old Oct 28, 2010 | 06:26 PM
omarrakeen's Avatar
what do you mean u didnt put the long tubes on? the engine was out of the car ? anyway if you are installing them then it depends on the headers but mostly you will need to remove it so you get much more space. i did remove mine and it helped alot.
Old Oct 28, 2010 | 06:27 PM
zracer323's Avatar
Are you removing stock manifolds or long tubes? I couldn't tell from your run-on sentence. Stock manifolds should be able to be removed easily without removing the steering knuckle. I also got my long tubes on without removing it. Others remove it to have a little more room to work with.
Old Oct 28, 2010 | 06:34 PM
PadenAlbin's Avatar
I had to remove the steering knuckle on my car when we installed them.
So I don't see why you could leave it on when your taking them off.
Old Nov 3, 2010 | 11:15 PM
kornboy's Avatar
Please rewrite this.First off what header brand is it? My school DID BIG MISTAKE???????????
