FAST 102 Vacuum Leak problem
Old Nov 2, 2010 | 11:19 PM
bucketlist1957's Avatar
I finally figured out my problem. It wasn't a vacuum leak afterall and my new found buddy from New Zealand was in the ball park on the PCV valve. I got to playing around and looking at another thread and noticed a guy put a breather on one of the tubes out of the passenger side valve cover. My 1997 has 2 tubes coming out ot the passenger side for the pcv system. I hooked them both up using a t connector for the front one. My car was sqealing like a hog stuck under a gate and I thought is was an intake leak. I disconnected one of the lines to one of the tubes out of the passenger side and all the noise stopped. I put a breather on this one and now everything is fine. No noise. Now I just need a tune. I am guessing the LS2 throttle body changed the intake vacuum enough to screw up the stock PCV air flow. It took me over a week to figue this thing out. Thanks for the ideas and help.
Old Nov 3, 2010 | 03:42 AM
ls1 1990 VN's Avatar
Hey Buddy, glad i could help steer you in the right direction,
Old Nov 3, 2010 | 12:44 PM
Talked to Ragin Racin. They explained how the TB is not reacting the same because of the big difference in size from stock. I am taking it to a tuner to get it tweaked in. Thanks again for the advice. Maybe I can pay you back some day.
Old Nov 6, 2010 | 06:05 PM
After figuring out the PCV problem. It was really one fitting causing all the issue. The elbow off the driverside valve cover was getting hot and collapsing on itself. I replaced all the lines with Transmission coolant line and moved the PCV to just before the oil catch can. I just finished having it tuned in Kansas City. This thing is running great. Now I am really happy even though it was a pain to figure it out. Uped the rev limiter to 6800rpm. Sounds great you can really hear the air sucking into the motor.
Old Nov 6, 2010 | 10:37 PM
Hey that's great, hopefully mine will be going by the end of the week. Mine uses a big pod filter, through that the sucking was loud,i was using a 78T/B & LS6 intake, can only imagine how much louder it will be through the 102/102
Old Dec 3, 2010 | 08:54 AM
Chevy Guy's Avatar
Interesting thread. I just installed a FAST intake on my 01 C5, I got a brand new 78mm model dirt cheap so I couldn't resist.
The intake itself is nice enough, but it is obvious that FAST tries way to hard to make their intake fit all models of LS equipped cars, resulting in individual fitment issues for each model. I cant believe for the price of these things how much work you have to do to get them to fit. I have heard that FAST has **** poor R+D and quality control, but now I have experienced it first hand. This is definitely my first and last FAST intake. For crying out loud, at least add a tab to hold the MAP sensor in.
I'm thinking of having my LS6 intake ported and pulling the FAST off and selling it.
All that being said - my car whistles as well once it warmed up. Its just a real short and low whistle when you first crack the throttle, during the transition from idle. It doesn't whistle at idle or when you are getting on it. I suspect the PCV or the purge hose as the FAST intake gas both pieces in non original angles.
Old Dec 3, 2010 | 09:06 AM
ShevrolayZ28's Avatar
I remember reading that the 78s whistle even when there's no vacuum laek, and there's a mod to get rid of the whistling. I can't find the thread, but I think something needs to be smoothed at the opening. Maybe FAST tech support can help you with that.
Old Dec 3, 2010 | 09:19 AM
Tony @ AFR knows how to get rid of the whistle...
https://ls1tech.com/forums/generatio...whistle-2.html
Chevy Guy's Avatar
Thanks a million, I will give them a call. Do you remeber where you may have read it?
Old Dec 3, 2010 | 09:24 AM
Look at post #28 just above
Old Dec 3, 2010 | 09:55 AM
Chevy Guy's Avatar
LOL!! Posted at the same time. Thanks!!!!!
Old Dec 3, 2010 | 10:06 AM
  #32
Ah the old simal-post lol.
...hey a couple-2-3 other things it could be if it's not a vacuum leak: it could be whistling through the IAC port in the throttle body, or through the port for the PCV's fresh air supply inlet. Or you might even have a stuck or backwards installed PCV valve.
I think the IAC motor moves a 'piston' in and out from blocking the port in the TB according to operating conditions (during cold start I'm guessing it's closed and then it opens once it warmed up, IDK could be the other way around).
PS you are using the special button head bolts for the valley pan, right? I hope the manifold isn't cracked!
