Swapping to LS6 pcv got a quick question
Old Nov 12, 2010 | 09:46 PM
kevins2000LS1's Avatar
Default Swapping to LS6 pcv got a quick question
Going to swap to the LS6 pcv. I currently have the LS6 intake with the ridges removed and LS1 coolant lines. Im wondering when I do the PCV swap are the LS1 coolant lines going to be in the way?
Old Nov 12, 2010 | 10:23 PM
Mumbles's Avatar
When I did my LS6 Valley Cover/Intake swap to my 99 Firebird I removed the factory coolant lines that ran under the intake.
Every thread that I had read told me they wouldn't fit between an LS6 Intake and LS6 Valley Cover. So what I did was purchase two front coolant lines and ran one at the front and one at the rear of the engine. I simply plumbed some 1/4" Fuel line from the rear tube to the front and connected them with a "T" Fitting and then on to the Radiator. Turned out pretty well.
This was my first and only experience with installing an LS6 Intake, so I haven't ever tried to run the LS1 Coolant Lines under the LS6 Intake. That being said, I don't see why you couldn't just remove the ribs and flatten the lines a bit to make it fit the same as if you retained the LS1 Valley Cover.
The only thing that may prevent this would be if the orifice on the LS6 Cover would interfere with where the coolant lines run. Other than that, you have the same amount of room between the intake and valley cover no matter which VC you're using.
I'm happy with the way mine turned out, but retaining the factory lines would have been a bit more simple and saved me a little money.
Try it and see.
Old Nov 12, 2010 | 11:32 PM
LS1Adam84's Avatar
If you remove the ribs under the manifold it fits over ls1 coolant lines, it has been done for a while. That's how mine is and it works great.
Old Nov 12, 2010 | 11:34 PM
djfury05's Avatar
which ls6 valley cover part are you using? if its the old style you better just return it and get the new one before screwing with anything. I have the old style on and just as much oil gets through... LS1howto.com has the old style part #
Old Nov 13, 2010 | 01:42 AM
JJsQwuik's Avatar
What's the new part # ?????????
Old Nov 13, 2010 | 02:14 AM
sjsingle1's Avatar
Old Nov 13, 2010 | 02:15 AM
sjsingle1's Avatar
Old Nov 13, 2010 | 04:07 AM
JJsQwuik's Avatar
^^^^^^thanks, this part is super cheap at gm parts direct dot com
Old Nov 13, 2010 | 07:32 AM
Unsure of which one but I got the cts-v crate engine ill have to look whenit gets here.
Old Nov 13, 2010 | 07:34 AM
Yeah thats how mine is now but im putting my intake on a LS6 engine with the new LS6 pcv valley cover. Wondering if the LS1 coolant lines will be in the way.
Old Nov 13, 2010 | 09:09 PM
rabbit320's Avatar
my bad if this is a newb question, but if i get a ls6 intake do i NEED a ls6 valley cover? or with some tampering of the fins get it to fit? sorry to hijack...
Old Nov 13, 2010 | 09:21 PM
ShevrolayZ28's Avatar
Nope. But you will need to change the coolant crossover lines. Look here:
http://www.ls1howto.com/index.php?article=5
Old Nov 13, 2010 | 11:34 PM
sjsingle1's Avatar
you can use either the LS6 coolant lines or your LS1 lines if you want....the LS1 lines require the shaving of the fins
Old Nov 13, 2010 | 11:46 PM
I just used a hammer and chisel and tapped the ridges off the bottom side of the LS6 intake
Old Nov 14, 2010 | 12:45 AM
sjsingle1's Avatar
i would use a power planer myself
Old Nov 14, 2010 | 05:40 AM
Props. That sounds like a nice cost cutting measure. The only minor concern I'd have is taking off too much or weakening the IM. Unlikely that that would be a problem imo.
