Exhaust opinion
Old Nov 27, 2010 | 07:54 PM
Justinktm's Avatar
Exclamation Exhaust opinion
before you laugh im not that smart with exhaust so heres the plan im getting pacesetter longtube headers and im going to do true duals so im wanting to know what else do i need.... EX: Tips or Muffler or both and should i do SLP or Flowmaster thanks
Old Nov 27, 2010 | 08:19 PM
DaveX's Avatar
You need everything from the headers back.
Old Nov 27, 2010 | 09:17 PM
Justinktm's Avatar
and what is everything from headers back?
Old Nov 27, 2010 | 09:21 PM
egott_91's Avatar
You'll need the headers, the mid pipe (since you're doing true duals you'll need either an x-pipe or h-pipe), the mufflers you want (whatever sound you like best) and then you'll need turn down tips, unless you plan on having an exhaust shop run it out the rear, then you should probably get tips, but if you're dumping it before the axle, you'll want turn down tips
Old Nov 27, 2010 | 09:32 PM
Justinktm's Avatar
would it be better to dump it before the axel?? and if i get an x pipe is that still considered true dual
Old Nov 27, 2010 | 09:38 PM
Smokinz28's Avatar
It depends on what you are doing with your car, and your budget. Texas speed makes a nice true setup. If you skip on the 02 sensors you will run rich unless you tune. Tuning is neccesary to pull every bit of power from your exhaust that you can. If your streeting your car youll need cats and o2 sensor extensions with your set up. Mufflers if you go with a setup that doesnt have them already, like one youll find in an exhaust shop. You may also need connectors like ubolts if your doing this in your driveway. You also might want to pick up a book. You should learn about cars in general before wasting money on things that may or may not work well with eachother. I do suggest, by the nature of your question, that you have some one knowledgable install your headers
Old Nov 27, 2010 | 09:39 PM
egott_91's Avatar
Dumping it befor the axle is cheaper and easier.
Yes, an x-pipe seems to be the preferred mid pipe for true duals. You'll want a bullet style muffler also, your brand of choice depending on the sound you like the best.
Smokinz28's Avatar
yes xpipes provide a feature called leaching, you would be a fool to go without a cross over of some sort.
Old Nov 27, 2010 | 10:06 PM
Justinktm's Avatar
SO tell me if this is right Pacesetter Long Tube headers to x pipe then to flowmaster bullet muffler and maybe some SLP tips?
Old Nov 27, 2010 | 10:15 PM
PontiacFan's Avatar
No, to the SLP tips. Why fancy high-dollar plated tips, hidden under the car?!?
If you want to 'dump before the rear axle', yes, now you're gettin' your layout a bit better. (Minus the SLP tips you've added to your list.)
If you want it to sound like a dump truck or some ranchers old Ford truckster, then you're headed down the right path.
If you want a better quality sound, then you'll need to do some more research.
If you dump under your backseat, ..., that's 1970's technology with a 1968 Ford Torino.
Go to LS1Sounds.com & listen to many combinations.
There are some 'true duals' that feed all the way to the back bumper that will 'sound' much better, IMO.
Old Nov 27, 2010 | 10:20 PM
Justinktm's Avatar
i dont want to dump the exhaust before the axel becuase im going put my car in shows so im wondering what kind of x pipe and all sorts of stuff do i need
Old Nov 27, 2010 | 10:30 PM
Smokinz28's Avatar
go with the texas speed. bolt it on tune it call it a day.
Old Nov 27, 2010 | 10:31 PM
Smokinz28's Avatar
no more than 500 duckets
Old Nov 27, 2010 | 10:40 PM
Justinktm's Avatar
im definately getting pacesetter LT but after that im making it true duals
Old Nov 27, 2010 | 10:56 PM
PontiacFan's Avatar
Some additional information may help the OP.
http://texas-speed.com/shop/item.asp...d=196&catid=56
Of course this will simply bolt up tot he LT's, but then you'll still need to finish it out. So not much help unless you have the capability of building the rest of the system, or if you have a local exhaust shop that can build it for you.
Do some research on the "Kooks True Duals" system. Very nice, but costly.
Some good exhaust shops may be able to build something similar for a lot less money.
http://marylandspeed.com/images/Camarokooksduals.jpg
Old Nov 27, 2010 | 11:00 PM
egott_91's Avatar
Bassani makes a true dual kit, not the cheapest. You can get PaceSetter longtubes, texas speed x-pipe and then take it to an exhaust shop and have them fab up the piping from the end of the x-pipe to the rear bumper.
Old Nov 28, 2010 | 03:23 AM
Justinktm's Avatar
ok what im doing is Pacesetter Longtubes with a 3in magnaflow exhaust ran from the header straight to the end of the car
Old Nov 28, 2010 | 07:15 AM
TXZ28LS1's Avatar
hey man, im running the exact setup your wanting. I have pacesetter longtubes, and i just installed TSP 3" Duals with dynomax bullets dumped. I love the sound. the ground clearance might not be the greatest. But i will say, your best bet is just to call Texas Speed and order your pacesetters and dual setup from them.
Old Nov 28, 2010 | 09:27 AM
egott_91's Avatar
So are you still doing duals? Cause from what I just quoted it sounds like you're going with a y-pipe setup and a magnaflow catback.
If you're still doing duals I guess you're getting two bullet magnaflow mufflers then having an exhaust shop run the piping to the rear of the car...
Honestly, I would do a little more research on exhaust before you jump to spend money on something you think is something it's not.
Old Nov 28, 2010 | 09:56 AM
garygnu's Avatar
there is a great sticky on exhausts,you can see alot of great exhaust set ups that look and sound great.
