LS6 valley cover question
Old Nov 29, 2010 | 04:05 PM
thirdgen60's Avatar
Default LS6 valley cover question
I have an LS6 style valley cover that came off of an 04 gto with the ls1. Is this the style cover that needs the pcv valve inline or is it built into the cover?
Old Nov 29, 2010 | 08:54 PM
Steve Gunn's Avatar
If it has a nipple on the front, it's built in.
Old Nov 29, 2010 | 09:34 PM
01ssreda4's Avatar
You need to post a pic. We have to be able to see the underside to give you a definite answer. That or the part number off the bottom. The nipple alone will not tell you this as some require the PCV valve and some don't. Just depends on whether it's a late model cover or early model cover.
Old Nov 29, 2010 | 09:40 PM
thirdgen60's Avatar
ok i didnt even think to check the bottom for a part number, when i go home this weekend i will check on the bottom. Do you guys know what the numbers of the new and old covers are?
Old Nov 29, 2010 | 10:30 PM
01ssreda4's Avatar
They are around here through the search feature. Mine is new style, note the holes in the bottom. No PCV needed.
Old Nov 30, 2010 | 02:08 AM
HoLLo's Avatar
Since you got one from an 04, it should be the newest style, they came on 04+ LS6/LS2. I installed the 04+ LS6 Valley Cover. Part number was directly from an 04 GTO. I had to replace knock sensors so I wanted to do it. Since then, oil consumption drastically dropped.
Old Nov 30, 2010 | 10:23 PM
sjsingle1's Avatar
Old Dec 1, 2010 | 01:01 PM
thirdgen60's Avatar
Thanks guys i appreciate all the info. Ill post what i find when i get home friday.
Old Dec 3, 2010 | 01:42 AM
01ssreda4's Avatar
Look for the holes
Old Dec 3, 2010 | 07:07 AM
bayer-z28's Avatar
Do you still need to dremel the block with the newer designs?
Old Dec 3, 2010 | 07:17 AM
01ssreda4's Avatar
Yes....
Old Dec 3, 2010 | 07:38 AM
bayer-z28's Avatar
Cool.. thanx..
[/JACK]
Old Dec 6, 2010 | 03:44 PM
thirdgen60's Avatar
So i took my valley cover off this weekend and i do have the new style that should have the pcv built in. The cover has the holes and the correct part number.
Old Dec 6, 2010 | 04:03 PM
01ssreda4's Avatar
Then you're money. No PCV valve required.
