exhaust leak...again, PLZ HELP!!!!
what should i do now?! why would it leak only when under heavy gas? could it be muffler constriction? because am using stock one. PLEASE help any suggestions? am using flow fking techs ( because i had to ) should i use paper gasket with rtv? am pissed
i think am going back to stock
ps: it only leaks from passenger side..is that common or what?
Find someone with a long enough belt sander (18"?) and hold the flange FLAT on there to even everything out. Check the flange with a straight edge first to find any warping or uneven spots.
flush again. what is the best way to do this? Is it possible to do without removing the exhaust completely? I see some have suggested two gaskets, will this be a temporary fix or will they hold up?
