MAF opinions
https://ls1tech.com/forums/multimedia-exchange/122490-tsp-231-237-cam-video.html
. dont let that stop you from asking questions though, as you stated thats the best way to learn. this system search feature isnt as good as other boards but you can usually find more or less what your looking for by typing in something general (i.e; true dual pics, best header, what LT's, new maf, ect.)and to the flowmasters defense it does sound good, my car came with it when i bought it used. it just flows like **** but sounds good. i had magnaflow next and now duals with 12" bullets
And about the MAF, when oxidizr was doing some baseline runs on my big-bore last week the car did 460rwhp with the stock MAF descreened then 460rwhp with an 85mm GMAF. Take that for what it's worth. That said, I hand-ported my MAF back when my car was mostly stock and it definitely felt stronger and I got better gas mileage, I think the 98 and 99's like ported MAFs.
almost everyaftermarket maf i have seen, for the LS1's is designed like i said. The SLP maf is nothing more than a truck maf, with a resistor soldered across the wires, can you say that that perfectly calibrates it to stock?
That is why people run lean, and that is why people have detonation problems with them,
If they were fully calibrated, then those problems would not occur.
On the LS1's can you honesty say that the stock maf is a restriction in the intake system?
And one question, you can try to answer for me.. when you say "calibrated" what does that mean. Im assuming that is gives as close of an output, as a stock unit?
The MAF is a sensor, and if you know the maf transfer function, you can tune for any kind of maf in any system. But nobody published any data for the ls1 mafs, to my knowledge, so that is hard to do.
Ryan
Hey I'm sure you've helped a ton of people out here, but even if you did know everything, that's no excuse to be a wise-*** with the noobs. The Best V8 Stories One Small Block at Time
and as for jrp, ive had some questions that he helped me out with before..and i greatly appreciate it.
..and i wouldnt give a **** if he told me i asked a dumb question...just as long as i get some useful answers.... Anyway, I descreened mine simply because the screen was damaged in one spot. Didn't seem to effect performance. You can simply take it in and out pretty easily - try it and see what happens - just give to puter a little time to adjust before you make a decision.
When you guys going to start building us some of your killer products?
