Wiring the Starter
Old Dec 8, 2010 | 07:58 PM
MetallicaMatt's Avatar
Default Wiring the Starter
Well my car has been apart for a good 6 months and I want to double check the wiring on the starter before I do it.
Anybody have a picture? 2 large posts and 1 small post on the solenoid if I remember correctly...
Old Dec 8, 2010 | 09:05 PM
bayer-z28's Avatar
Yep... Pretty simple.. Power in, power to starter, and a trigger. The starter or solenoid should ground thru the mounting surface.
OR
Old Dec 9, 2010 | 05:11 AM
So just the 12v Switched (small wire), and the large positive. I don't remember a ground?
I'll look tonight...
Old Dec 9, 2010 | 06:15 PM
There is a wire from the starter, Just stick that to the closest large post and the other large post is the hot from the battery. Small post is from the 12v switch?
