Coils??????
Old Dec 9, 2010 | 09:18 PM
LS1121's Avatar
Default Coils??????
I have a 1998 Z28 with 254,000 miles and I have issues. I am wondering what coils can I put on my car. Like from what other cars or trucks will fit my engine? Thanx!
Old Dec 9, 2010 | 09:28 PM
Paul Bell's Avatar
That's MISTER MODERATOR
LS1/6 coils had their own plug pattern. LSanythingelse coils won't work unless you change the coil harness to LS2/3/7 style. Also, your coils mount directly to the valve covers, right? No other coil will mount.
You won't notice any improvement over the stock LS1 coils unless you move to the round truck coils with exposed heat sink on the back. Additional improvements can be had with the coils with a tune.
Stay with the stockers. Go with GM coils. Don't buy the MSD coils, they're no improvement over stock and have a high failure rate.
Old Dec 9, 2010 | 10:15 PM
sjsingle1's Avatar
truck coils FTW
Old Dec 10, 2010 | 12:22 AM
LS1121's Avatar
Nice picture, what truck coils would I look for? for my 1998 will need to fit the valve cover , correct? because there is valve cover change in 1999.
Old Dec 10, 2010 | 07:02 AM
Paul Bell's Avatar
Any truck that has coils that look like those with the heat sinks on the back.
You can't change valve covers as yours are perimiter bolt, not center bolt.
Everything you'll need to know is in this one post:
https://ls1tech.com/forums/12985321-post1.html
Old Dec 10, 2010 | 07:10 AM
Paul Bell's Avatar
Nice job SJ. I see you've moved the brackets downwards one inch to clear the junk above. I'd have made the bracket blue tho...
Old Dec 10, 2010 | 07:42 AM
reeperz28's Avatar
https://ls1tech.com/forums/dynamomet...en-inside.html
i seen this the other day not saying to not go with them but there is no power increase .. they are easy to find and probably can find them on a 99-up 5.3 silverado at a junkyard or anywhere for cheap
Old Dec 10, 2010 | 08:58 AM
thunderstruck507's Avatar
What issues are you having that you are blaming the coils for?
Old Dec 10, 2010 | 09:31 AM
brian_rs/ss's Avatar
exactly. PLEASE let us know what you have done to trace it to the coils AND what you have done to try to fix it. chances are there is an underlying problem or another problem entirely.
Old Dec 10, 2010 | 10:17 AM
LS1121's Avatar
Well I've changed the plugs and wires, I've taken the car to 2 different muffler shops to check the exhaust flow and they both told me everything was OK. The car does have many miles on it. This is my daily driver, about 200 highway miles every day. When I drive at a normal pace, or even when I need to get past some knucklehaed on the highway everything is good. The car does not miss or sputter. BUT when I jam down on the gas to get rid of a pest that is bothering me the car will hesitate spit a bit then take off. I checked my gas milage yesterday and I am getting almost 26 mpg.
Old Dec 10, 2010 | 10:24 AM
you are probably running lean, when was the last time you had a diagnostic ran? are you still on the factory fuel pump?
Old Dec 10, 2010 | 10:26 AM
O2Form's Avatar
Replace the fuel filter before you do anything more.
Old Dec 10, 2010 | 10:38 AM
Was it doing it before you changed the plugs/wires? If not, you have a 99.9% chance you cracked one or got a bad wire.
If it was, you need to have a scan ran to find out which cylinder is misfiring or if all of them are. If it's just 1 or 2 move the coils around and see if it follows. Then move the injectors around or replace them with known good ones and see if it follows.
Replace the fuel filter regardless if you haven't done so recently. I check mine at least every other oil change, if you can't effortlessly blow through it with your mouth (connect a short piece of clean hose) then it's trash.
Check WOT fuel pressure.
Old Dec 10, 2010 | 10:49 AM
LS1121's Avatar
Oh yes one other thing, when I jam on the gas the SES light comes on for both of my front O2 sensors.
yes gas filter I did not think about that. where is it? sounds stupid I know.
Old Dec 10, 2010 | 10:52 AM
LS1121's Avatar
where would I go to get a diagnostic run and about how much should this cost? Thanx everyone for your replys. I really don't want to go to the Dealer.
Old Dec 10, 2010 | 10:53 AM
I would also check your wiring harness, especially the tail end. Could be getting pinched and grounding out. Also check closely around the headers/crank sensor harness near the starter.
Also check your harness grounds.
Any black smoke from the exhaust?
Old Dec 10, 2010 | 10:57 AM
where do u live? go hit up the regional section for a reputable tuner in your area. have them run a diagnostic, and try to track down the problem. until then do as suggested with the fuel filter. if you don't know how either search it on here or go grab a chilton's manual.
Old Dec 10, 2010 | 11:25 AM
LS1121's Avatar
OK I will do that Thanx to All. I live in Charlotte NC.
Old Dec 10, 2010 | 12:02 PM
Anyone with a Snap On MT2500 scanner should be able to look for $50 or so...maybe an hour shop labor at most.
Old Dec 10, 2010 | 05:20 PM
Paul Bell's Avatar
I agree with everybody else here. A good tuneup which includes plugs, wires, fuel filter and maybe pulling the TB for a good cleaning including the IAC. The fuel filter is located in front of the rear left tire. Find a Bosch or Wix filter.
With your mileage, you probably also need at least the front O2 sensors. You'll do well with Bosch 13111 O2 sensors for a Corvette. Longer cables and higher wattage heaters so you'll get to closed loop quicker. Many here run them.
IF you really think it's a coil, buy one or two (stock) coils from GM and swap them around and driving the car to see if the problem goes away. I would NOT reccommend you do the coil change to a LS2 truck version.
