Holley Intake worth it??
Old Feb 8, 2004 | 01:29 AM
Ryan K's Avatar
Pathological Modifier
I like mine. Its port matched to my Stage 3 ARE heads.
Ryan K.
Old Feb 8, 2004 | 07:21 AM
LPE SS's Avatar
Originally Posted by Hugger SS
metal intake = inducing heat
I'm up to speed on the hot air - bad, cold air - good thing and I can certainly appreciate wanting cool, dense air for optimum power BUT how much warmer does it get? How much power is lost? I certainly won't deny that the thermal properties between aluminum and Nylon are considerably different, but unless you can show those interested in this intake these SIZEABLE, measureable differences that impact engine performance negatively then a general comment like metal intake - bad, plastic intake - good is pretty useless unless backed up by some good 'ol fashion recorded facts.
Aluminum can't be that bad...they've been on cars long enough, haven't they? I hope you or anyone else is not under the impression that GM designed a plastic intake specifically for our beloved LS1's because the LS1 is heat sensitive?
LPE = overpriced? 'Can't afford it' comment was tongue-in-cheek retaliation. Do the homework and you'll find there are other shops out there just as and defineately MORE expensive. Scroll through our sponsor's list once... . That's another thread though....
Baller? What or who am I balling?
Originally Posted by Country Boy
LOL... its so great that they use the plain ol' LS6 intake instead of their own intake That right there should tell you something.
All that should say is that LPE does not use them on their packages. Doesn't mean they can't or the intake is bad. The power difference between the LS6 and Holley is marginal at best. It wasn't designed to out perform the LS6 out of the box. Port it out or squeeze a direct port ha-ha gas on it and now its a different story. As bad 30th mentioned, the intake was designed around the LS6. The Holley has more fab options that's all.
Old Feb 8, 2004 | 08:06 AM
TEA Brent's Avatar
We use that intake on our Nitrous C5 Vette, and once it was ported it made more power then an LS6 and will not break with a nitrous backfire.
We went 9.80's with 600 RWHP on the spray with our 5.3 Stg 1.5 heads, added the Judson LS6 Stg 2.5 heads and Weiand intake and picked up 90 RWHP!!
Old Feb 8, 2004 | 06:45 PM
LINGENFELTER SS's Avatar
Lingenfelter = overpriced name.......[/QUOTE]
Overpriced how?
Lets just say they pay extra for being Silent Killers.
You cant tell the difference between
stock cars w/ exhaust, and there heads and cam cars.
Even there 427 TT sound like they only have exhaust.
Well till they blow ur doors off in the 9sec 1/4 fashion.
Dont bash LPE if you never saw there cars. K.
Old Mar 19, 2004 | 11:21 AM
SShark's Avatar
Don't all the Zl1 berger 427's use the holley intake?
Old Jun 16, 2005 | 05:32 PM
JustAnIlluzion's Avatar
would ceramic coating the manifold help with heat issues? most cars have aluminum intakes and the aftermarket ones are aluminum too, i dont see it being a big issue, if i can find a used one for a good price, il take it over a polymer one.
Old Jun 16, 2005 | 09:16 PM
jrp's Avatar
jrp
SN95 Director
even if you take out the heat soak issue the LPE/Wieand intake flows exactly what an stock ls6 intake does, even when ported. "porting" is somewhat a misnomer as the hatch doesnt allow much room to get much real port work done.
check the intake flow test in the FAQ (sig)
and damn this is an old thread...
Old Jun 17, 2005 | 02:18 PM
LPE SS's Avatar
Yep...REEEEAL old!
Bad memories
