Power steering cooler has slight leak
It does not appear to be where the nipple connects to the metal tube. But rather where the hose connects to the nipple. The hose is wet from that point down to were it curves upward near the steering pump. No water is dripping on the ground.
If I were to replace the squeeze clamp with a screw type clamp. Will water drain out when the hose is disconnected?
Any thoughts/advice on the matter is appreciated. Getting ready for a 300 mi trip soon.
Then I recommend using a high pressure fuel injection clamp to retain the line.
They hold pressure lines better than worm type clamps.
Of course it is. Just call me DumbAzzWayne. Thanks.
