MAF question
Old Feb 7, 2004 | 11:16 AM
romanss's Avatar
Default MAF question
I have this MAf that came off of my car. I don't really know for sure what it is. I was told that it's a Z06 maf. But I want to make sure myself. Needless to say where I got it from, I don't believe them.
It has DELPHI on it.
It has the screen.
It has the connector to convert from 5 pin to 3 pin
Anyone?
Anything else to look at?
Physical size to check, where to measure?
Thanks,
Roman
Old Feb 7, 2004 | 11:47 AM
NightHawk's Avatar
I know the truck MAFs (like SLP uses) say "Delphi" on them and have a front screen...not sure about the Z06 ones though. Either one should measure 85mm across.
Old Feb 7, 2004 | 08:49 PM
jimmyblue's Avatar
Moderator
Do you see a GM-looking part number on the flat
face of the "pecker"? If so, post it up. If it looks
like the number has been Dremeled off then it may
be an SLP MAF that lost its little vinyl SLP badge.
SLP MAF is the truck MAF with a resistor soldered
onto it.
Old Feb 7, 2004 | 09:51 PM
romanss's Avatar
onto it.
Yup it has been dremelled off.
Is there a way to check it to be sure?
Thanks,
Roman
Old Feb 8, 2004 | 10:12 AM
jimmyblue's Avatar
Moderator
If it's the SLP MAF then you should see a resistor
wrapped in heat-shrink tubing, soldered in there
like this:
http://community.webshots.com/album/62584862vRyXVK
Old Feb 8, 2004 | 05:14 PM
romanss's Avatar
like this:
Thank you very much. I have a SLP MAF.
Thanks,
Roman
