just installed my pacesetters.
Old Feb 7, 2004 | 06:52 PM
taqwache's Avatar
Default just installed my pacesetters.
i know that this has been talked about before but oh well. on the driver side i only had to remove the lower intermidiate steering shaft and grind about an 1/8 inch on the k-member. they acually did not hit at all but it was very close. i am sure that with the engine on it would rattle on it so i spent about 5 minutes on it with a carbit bit di grinder. the passenger just slid right in place like if it was a stock part. also they are not near the bottom of the car eather.
Old Feb 7, 2004 | 08:15 PM
SSactionLs1's Avatar
Old Feb 8, 2004 | 08:47 AM
demonspeed's Avatar
It's not mine! woo hoo!
You using their flat ypipe, or going with something else?
Old Feb 8, 2004 | 09:42 AM
shawn's SS's Avatar
Jack stands or did you have a lift?
Old Feb 8, 2004 | 12:49 PM
CamaroCain's Avatar
here are a few problems i ran into doing it. We ended up putting in the driver side poly motor mount to help out a little and my hubby did some grinding. Yes the passenger side was very easy to do.
Attached Thumbnails just installed my pacesetters.-picture-001.jpg   just installed my pacesetters.-picture-005.jpg
