how hard is it to change spark plugs
Anyway my arms still bare the scars from those "F"ing plastic plugs under the cowl!!!
That bolt is tough as hell, but it is such a wonderful feeling to remove it and throw it in the bushs!
Tommy
This is the best advise I could give too. It cuts the work time in half. I get to #8 from the top and I actually have a harder time with #6. A 1" extension helps a good bit too.
Tommy
all you have to do is take off panel,find motor,find the rivets,drill 3 holes in the in the panel in front of motor,drill out rivets,make the holes big enough for the three bolts on the motor and bracket,bolt it on and your done
all together about a 1.5 hour job
damn thing was fouling up the plugs quicker than I could **** on em
THAT is why Im relocating my coils under the cowl, and already had Jantzers' shave/powdercoat my valvecovers
Tommy
