how hard is it to change spark plugs
Rob
the one thing that makes #8 EASY from the top, is this rachet
found here: http://www.sears.com/sr/javasr/produ...id=00944835000
this rachet is the best thing I've bought for this car, the only thing it's missing is a latch or lock or something, to lock the head in position
If you have that, along with a decent extension set, standard sparkplug socket, and a swivel-socket, your good to go
It took my a little less than an hour for all 8 plugs my first time. There is really no need at all to go from the bottom.
These work great:
http://www.harborfreight.com/cpi/cta...emnumber=31203
Tommy
I ened up using a 1/4 drive and deep socket 10mm and just jammed on in that bolt and moved the heater hose out of the way even though the hose didn't want to budge much. I was able to bust the bolt loose a bit, then was able to undo it all the way by comming from underneath with a homemade (read hack sawed!) stubby 10mm closed end.
In all, I think I spent more time just busting the wire boots off the dang plugs. Those boots are on there TIGHT!
There is no way to get to #8 from underneath on a '98 with stock exhaust. You can see it, but you can't touch! You can only get it from above, with much agony and suffering in the process. Anti seize is our friend.
i have a lot of work this weekend
1st do sparkplugs,i also have to change the driver side window motor,and power steering pump pulley that some how got a chip so wish me luck
thanks again
Tommy
You must have it tough. I'm six foot (185) and have problems squeezing my arms (large forearms) into certain areas. I gotta see you slide under the car while it's on the ramps.
