Are 4.10 gears normally loud?
EDIT: I'm big on running only GM brand gears. I have found they seem to be the quietest. Others may disagree.
As correctly pointed out by 01SS, aftermarket "performance" gears are stronger due to their cut but often make more noise.
Unless you're producing serious power, GM gears should be all the gear you'll ever need.
Hi,how did your mesh pattern look on the ring and pinion. The backlash setting is also important for the aforementioned issues. The break in period should help after a few heat cycles. I would also check my axle bearings as rear noise can fool the best........have a blessed day........jim
