Looking for high flow cats
Old Jan 25, 2011 | 01:20 PM
doomss's Avatar
Default Looking for high flow cats
I absolutely have no idea / experience with cats at all. Shortly after I bought my car I installed a Pacesetter ORY, Pacesetter LT's, and LMII and it's been that way since. After installing my cam, cops in small towns don't like how loud my car is, so now I am in the market for cats because I'd rather just get a noise complaint than a huge fine. Are the best high flow cats that I can use with my Y the Magnaflow 3"?
Old Jan 25, 2011 | 01:36 PM
MikeWS6's Avatar
I have used thunder bolt high flow cats with good results. They should take care of most of the rasp.
Old Jan 25, 2011 | 01:44 PM
RARON455's Avatar
Both dynomax and magnaflow make hi flow cats from what I know,,However if its just the visual inspection by the law you are worried about then look up non-catalytic converters, they look just like converters but are straight pipe on the inside, cost about 30 dollars a piece online.
Old Jan 25, 2011 | 01:53 PM
doomss's Avatar
Well my inspection is also coming up in April so I think maybe I should get real cats instead of just "visual aide"
Old Jan 25, 2011 | 02:04 PM
Paul 1953's Avatar
2 questions:
1) What's cheaper & easier: cutting your ory and welding in new cats, or just buying a hi flow catted y?
2) Will cats really help with the loudness or just the rasp?
I just added a cam to my Kooks LTs and Kooks catted y and my nice Corsa muffler was suddenly too loud, although there was no rasp. Yeah I too was worried about cops. I put in a quieter Magnaflow muffler. Problem solved.
Old Jan 25, 2011 | 02:18 PM
doomss's Avatar
My main concern is really being visually inspected and also state inspection. I don't mind if the car is loud because that's a simple $50 ticket, I just don't want a routine inspection to lead to more problems.
I'd imagine it's easier to get a new high flow catted Y pipe.
Old Jan 25, 2011 | 03:15 PM
99Bluz28's Avatar
You can go with the TSP Cat Y-pipe, or get a set of Magnaflow (#59959) cats for $150-$200 a pair. If you go with the just the cats, then you'll need to factor in labor cost to install them, unless you're going to do it yourself.
http://www.texas-speed.com/shop/item...d=189&catid=45
Old Jan 26, 2011 | 06:41 AM
SS4Luck's Avatar
Ive always seen good numbers out of Kooks cats
 Michael S. Palmer
