MSD-8733 2-Step
Old Jan 26, 2011 | 11:37 AM
bamaballa205's Avatar
Default MSD-8733 2-Step
Do anyone have a complete write up installing the MSD 2 step? Want to install mine through the clutch and want to know the exact wires to connect with. Thanks
Old Jan 26, 2011 | 02:12 PM
jmm98LS1's Avatar
I used the starter safety switch for mine. I pulled the factory wires out of that switch and connected them, so now the car starts without pressing the clutch in (be careful!!). I took the msd 2 step activation wire and ran it to one side of the switch, then ran the other side to a ground. So when the clutch is pushed all the way to the floor the 2 step is activated, and it shuts off as soon as soon as the pedal moves.
Old Jan 26, 2011 | 02:45 PM
So u used the solid blue wire for the ground instead of the blue/white for 12v. Sweet deal man. I think I can deal without using the clutch to start the car.
Old Jan 26, 2011 | 03:19 PM
jmm98LS1's Avatar
Yep, solid blue wire. Just always remember to take the car out of gear before starting it with that safety switch disabled!!!
Old Jan 26, 2011 | 03:44 PM
Preciate it man.
Old Jul 3, 2013 | 05:05 PM
foxriderry's Avatar
What wires does the starter safety exactly consist of? Like colors and what not? And where is it located? I wanna wire mine the same way
Old Aug 1, 2014 | 12:34 AM
Gaspo's Avatar
i've searched all over, and none of these threads give me the answers i need either. i have the "8733" 2 step. 97 c5. what wire do i hook up to ground and what wire do i hook up to the clutch switch? there is a blue wire and a blue/white wire coming out of the box. also, there are two switches for the clutch. the one up top (clutch engaged) has a purple wire and gray wire. And the switch at the floor (clutch fully disengaged) has a purple wire and a yellow wire. please help!!!!!
