broken exhaust bolts
Old Feb 11, 2004 | 07:47 PM
mccool98ta's Avatar
Default broken exhaust bolts
hey guys! what is the approved method for removing broken exhaust bolts connecting the y-pipe to the manifolds and the cat back. can you press them out or do they have to be drilled out? thanks
Old Feb 11, 2004 | 07:52 PM
Doc's Avatar
Doc
What do you mean by "broken?" Do you mean stripped? Drill em' and turn an easy out in em' and wrench em' off.
Old Feb 11, 2004 | 08:11 PM
slik98z's Avatar
dude i did the same thing taking my y pipe off my stock manifolds. 4 of the 6 busted. i just used one of those air saws at my buddies shop, and cut them off as close to flush as i could to the manifold then just took my time to drill them out dont get greedy with the drill bit, just take your time, its not hard just time consuming and tiresome. if you can get the easy out in them and wrench them off, thats easier, but if they are like mine, mine busted off so close that it was basically grinding them down so i could drill them out more quickly, either way just take your time, be careful and get some better bolts in there.
good luck man
Travis
Old Feb 12, 2004 | 12:06 AM
black_z's Avatar
I used a torch and a vice grip.
Old Feb 12, 2004 | 01:05 PM
JHarmon's Avatar
Smoke wrench and vise grips or LH drill bit and EZ out. Good luck.
