High mileage LS1 questions...
Second, my power steering fluid has recently become contaminated. It doesn't seem to leak unless the car is running. I let it idle for about 5 minutes after a short spirited drive and it left a puddle about the size of credit card in my driveway. I'm thinking a new cap for the reservoir is needed.
Third, my car is still running the stock timing set, oil pump, and water pump. For the timing I understand the LS2 set is a direct replacement. Am I correct in that thought, or is there more I need? I was also looking for some suggestions on the oil pump replacements and testimonials. For the water pump, I was thinking a Meziere ewp 55gpm unit. I figure it would likely outlast this engine and move to whatever gets put into this car when the time comes. Any ideas, suggestions I would like to hear them. I'm thinking about putting tracer dye into the coolant and doing a compression test on the engine to see if its worth the time to install this stuff and the money involved.
