SES light came on
Old Feb 13, 2004 | 07:45 AM
DreamState23x's Avatar
Default SES light came on
I started changing my plugs and wires wednesday, I only changed the driver side and was going to do the passanger side last night, but on my way home from work last night the SES light came on.. Could this be from the new plugs and wires being only on one side, I have read that you can space it out like that, do one side one day and the other the next.. Im going to go get it scanned in just a little bit to see what the scanner says. Just thought I would see if anyone has had this problem before or not. Thanks.
Old Feb 13, 2004 | 08:00 AM
Slowhawk's Avatar
LS1Tech Sponsor
Can you feel it missing?
Could be a plug wire loose.Did you check the plug Gap before installing?
Old Feb 13, 2004 | 08:02 AM
ss rally red's Avatar
Is it flashing? if so there is a misfire condition, check plug and coil packs on the side you changed make sure the wires "click" on both sides.
