Bad maf?
Old Feb 13, 2011 | 10:53 AM
ffrh911's Avatar
Default Bad maf?
Everytime I run the car a little hard afterwards for awhile when I out in nuetral it acts like it wants to die and drops to 500rpm Then back up to 800ish and does this a few times or untill I give it some gas. It does about the same thing like when the maf is dissconnected.
So is it maf
or tune for my mods?
Old Feb 13, 2011 | 05:44 PM
jlrz28's Avatar
10 Second Fun Car
Try changing your tps, I had similar issues in the past. The easiest way to see this is with a programmer or some kind of monitor that will show you your throttle percentage.
Old Feb 13, 2011 | 06:09 PM
ffrh911's Avatar
The throttle percentage looks normal. What should it be at around idle?
Old Feb 13, 2011 | 08:36 PM
jlrz28's Avatar
10 Second Fun Car
I cant remember right off hand, the problem I had was it would just start surging and you would see the percentage changing. If you want to clean your MAF just use some electronic contact cleaner and a qtip, it may help.
Old Feb 14, 2011 | 11:27 AM
ffrh911's Avatar
I used actual maf cleaner from an auto parts store and of course some
qtips 4-5 months ago
Old Feb 14, 2011 | 11:30 AM
ffrh911's Avatar
I'm going to take it for a test run and see if it'll do it again and I'll check the diablo
Old Feb 19, 2011 | 11:08 PM
ffrh911's Avatar
I cleaned the maf there was actually some nasty gunk but I took care of it. The maf reads 6g/s at idle And goes to 235ish at WOT.
is there anyone that can give me an explonation? Will the maf just startcutting out like that when going back to idle?
