Jet Hot Headers?
Old Feb 13, 2004 | 11:49 AM
VoodooWS6's Avatar
Default Jet Hot Headers?
Any feed back on the Jet Hot's? Easy to install and last well?
Old Feb 13, 2004 | 12:08 PM
SSCamaro99_3's Avatar
Mine have been on for 11 months. There is a little surface rust in a few place, but my car is no garage queen. They clear my heater box fine, and the K-member did not have to be ground. I have been very happy with them.
Old Feb 13, 2004 | 01:35 PM
Bowtieman4life's Avatar
I like them and they were easy to install w/ no grinding.
Old Feb 13, 2004 | 03:29 PM
Turo's Avatar
weird, i had to grind my k-member a bit, but it was a very easy install (the were just barely touching the k-member, so i grinded it just to be safe). id recommend them
Old Feb 14, 2004 | 06:27 AM
Trans_AmGuy's Avatar
I just replaced my Macs with Jet Hots yesterday. Did the install by myself and it wasnt too bad. The easiest way is to unbolt the engine mount on the passenger side and jack up the motor a little until you get enough clearence to slide the header in. Then let the motor down and fasten the motor mount again. The driver's side.... just take off your steering linkage and you'll be set. BTW I didnt have to grind the K member. They sound much deeper then the Macs!!!!!
