help installing asp crank and alt pulleys
what i did to get the alt pulley off, since no matter how hard i squeezed the belt together even with vice grips it still stun, was take a small screwdriver and jam it in there to stop it from spinning. it worked, however when i pulled the screw driver out it was bent like an L and one of the blades inside the alt was stuck on the side and it wouldnt spin, so i had to use another screwdriver and a hammer to bang the blade back into shape so i would work again
DONT DO WHAT IT DID
DONT DO WHAT IT DID
That sounds like a very bad idea
